MWS Pre-Wired Nano Biscotte Sound Module V4
The sound module comes with a SD card preloaded with both the Light and Dark Meat sound fonts. You can add your own sound fonts to the SD cards as well.
If you would like to purchase additional sound fonts please visit
SaberFont.com Light Meat sounds Dark Meat sounds Owners Manual This is the MWS pre-wired version. These boards come wired with JST connectors for the following connectors. •1x Main LED (Blue- White+ Female JST) •1x Switch (momentary only) (Yellow Female JST) •1x Battery (Black- Red+ Female JST) •1x Speaker (Green Male JST) •1x FoC lead (Orange- Red+ male JST)
Do not solder to the module while the SD card is installed and do not remove or install the SD card while power is applied to the module. THE WIRING HAS SLIGHTLY CHANGED (so don't hard swap a V2/3 in place of a V1)
From top to bottom, board pinout (changes in bold):
** Positive (+)
** Negative (-)
** Luxeon (-)
** FoC pad
** Activator switch
** Speaker
** Speaker
Nano Biscotte Features & Maximum Ratings
- 3 fonts - Long press on the activation switch when blade is off make the saber switch to the other font. Comes with Lightmeat and Darkmeat
- Flash On Clash™ (FoC™) compliant using built in Power Extender
- Improved file fetching, up to 16 GB µSD card, drag and drop compliant (tested on PC at least)
- Dimensions : 1.12" x .73" x .20"
- Power supply : 3.4 to 5.5v / 2A (with the High-power LED). SINGLE li-ion cells (18650 or 14500) or 4xAA rechargeable NiMH batteries recommended.
- Idle current consumption : < 0.09 mA (deep sleep mode)
- 7+ months of shelf time with a fully charged 18650 li-ion cell
- 2A high-power LED direct drive (no current regulator)
- Speaker : 4 to 8 ohm.
- Audio output Power : 2W max
- Exported 3.3V pad
- Handles only momentary switches for blade activation
- Blade Flickering Fx
- Blade Shimmering on Clash
- Anti Power Off technology (A-POP™)
- WAV file support
- Changeable sound fonts, drop in support of CF/PC fonts, extra sound files are ignored.
- 10 bit, 22.050 ksample/sec audio
Warranty
- Warranty is for 30 days from the date of purchase.
- Warranty covers defects in workmanship and materials under normal use and service.
- Damage due to improper soldering will void the warranty.
