MHSV1 Clamps & Boxes
Hilt side Adapters
PCB's and Pins
KR Pixel Thick Walled blade 1" OD x 32.875" long V2
TWBattlePXL32V2
$124.99
Also in Pixel Blades
Complete Pixel LED Trans White Show blade.
The blade is assembled with the V2 Pixel Stick, Foam, "TCSS" Style plastic diffuser for extra diffusion, and a Parabolic tip. There is no custom lengths and the Blade is offered at a fixed 32.875" in length.
NOTE: You will want to set your strip configuration to 132 LED's.
The blades are not designed for Dueling.
These Blades include a 90 Day warranty and it does not cover any damage to the blades as a result of Dueling or Bashing. If a blade is returned back to us showing signs of abuse, the warranty is void.
KR Pixel Show blade 1" OD x 32.875" long V2
$124.99
More Info
KR Pixel Show blade 7/8" OD x 32.875" long V2
$124.99
More Info
KR Pixel Show blade 7/8" OD x 35.375" long V2
$124.99
More Info
MHS V2 Long Choke Style 4
$15.75
Faux Transistor
$14.98
Pommel style 6 with Sound Holes
$45.99
MPS Pommel style 3 v3 with D-Ring
$28.75
4.2" Male / Female extension Style 6
$18.50
