Canadian Customers
MHSV1 Clamps & Boxes
Canadian Customers
Canadian TrustFire Protected 3.7V 900mAh 14500 Lithium Battery (2-Pack)
CTrust14500
$6.99
Also in Canadian Customers
THESE ARE FOR CANADIAN CUSTOMERS ONLY
TrustFire Protected 3.7V 900mAh 14500 Lithium-Ion Battery (2-Pack)
MUST BE RECHARGED WITH A LI-ION CHARGER. DO NOT USE A NIMH CHARGER.
We recommend that the batteries be charged individually out of the hilt and not be setup as a rechargeable pack.
As with any battery they should not be left in the hilt for extended times while not in use.
- Shell material: steel
- Rated voltage: 3.7V
- Internal resistance: - Low voltage cut off: 2.75V
- Over charge voltage cut off: 4.2V
- Maximum charge current: 1.5C
- Maximum discharge current: 1.5C
- Diameter: 14.0 +/- 0.5mm
- Height: 51.5 +/- 0.5mm
- Environmental temperature (operating): 0~45'C
- Environmental temperature (charging): -20~60'C
DO NOT USE LiIon batteries if you don't know the dangers about them and how to handle them. Please check out this resourceful
website
on handling, charging, storage of LiIon batteries. Use at your own risk
Canadian TrustFire Protected 3.7V 2400mAh 18650 Lithium Battery (2-pack)
$10.50
Canadian Li-Ion 18650 3.7V 15A 3000mAh PCB Protected Rechargeable Battery
$15.99
Canadian 7.4v Li-ion 1400mAh 18500 Battery Pack
$16.99
Slothfurnace ROTJ card for box 28 upgrade
$12.00
MTN Neck Style 9 Copper
$25.99
MTN Neck Style 8 Brass
$19.99
MTN Neck Style 8
$7.49
12mm KR Aluminum Duo Tactile Switch w/6" Leads
$14.50
