Bullet Shaped White shouldered 7/8" thin walled blade tip with reflective disc
  • SKUW78Bullet-R
White shouldered 7/8" bullet blade tips with reflective disc for 7/8" thin walled tubes.
These tips will light up if you cut a small section out of the middle of the reflective material or remove the reflective disk.
Average rating 6 out of 10 ( based on 1 review )
Meh.
Review by Conner on 2/6/2023
The shape is good and the mirror is even and good for lighting up the middle of the blade but this tip won’t light up much at all, maybe a little around the plug but realistically I’d go with the clear bullet shaped tip.
