MHSV1 Clamps & Boxes
Hilt side Adapters
PCB's and Pins
7/8" Thin walled Trans White parabolic Pixel blade tip
78TWPBTNNP
$5.50
Also in 7/8" Thin Walled Blades
Transluscent white parabolic tip with shoulder for 7/8" thin walled blades. Has a hollowed tip for the neopixel to recess into.
These are created using new material that will illuminate way better than the previous white tips.
7/8" Thin Walled Pixel Blade Adapter
$4.00
40" LED blade diffuser for 1" thick walled blades
$3.95
Foam tube for 7/8" thin and 1" thick tubes V2
$7.00
Slothfurnace ROTJ card for box 28 upgrade
$12.00
MTN Neck Style 9 Copper
$25.99
MTN Neck Style 8 Brass
$19.99
MTN Neck Style 8
$7.49
12mm KR Aluminum Duo Tactile Switch w/6" Leads
$14.50
