• TrustFire Magnetic Battery Charger
Item #: TrustUC10
Our Price: $4.99
TrustFire Magnetic Charger with powerbank function. Universal charger for 32650 14500 16340 26650 18650 21700 cells.
Charging port Input: 5V/1A Output to battery: 4.2V/1A(Max 1.2A)
Discharge port output to other electronic devices:5V/1A
Net weight:18.2g Made of high-quality plastic materials
Working temperature:-20℃- 50℃ Working humidity: 5%(0℃)- 90%(40℃)
1)Reverse connection protection: The indicator will flash the red light in seconds.
2)Overcharge protection: Maximum constant voltage 4.2V
3)Short circuit protection: positive/negative short circuit protection (90mA detection current will be generated)
4)0V activation: 0V activation with battery protection plate.
USE IN A FIRE SAFE AREA ONLY
