Nano Biscotte Sound Module V4
The sound module comes with a SD card preloaded with Lightmeat, Greymeat and Darkmeat sound fonts. You can add your own sound fonts to the SD cards as well.
If you would like to purchase additional sound fonts please visit
SaberFont.com Light Meat sounds Dark Meat sounds Owners Manual Do not solder to the module while the SD card is installed and do not remove or install the SD card while power is applied to the module.From top to bottom, board pinout (changes in bold):
** Positive (+)
** Negative (-)
** Luxeon (-)
** FoC pad
** Activator switch
** Speaker
** Speaker
Nano Biscotte Features & Maximum Ratings
SPECS
[NEW] Up to 3 fonts - Long press on the activation switch when blade is off make the saber switch to the other font. Comes with Lightmeat, Greymeat and Darkmeat
[NEW] Configurable reboot delay
[NEW] Adjustable beep volume
[NEW] Up to 16 swing and 16 clash sounds
[NEW] Dual Digital Sensor motion detection. Identical to CF MotionFusion, very high swing sensitivity and vibration immune
[NEW] Mute-on-the-go(MOTG) with configurable delay
[NEW] Mute during power off. Optional silenced power-off sound when MOTG is engaged
[NEW] 3 channel color "mixing" - 4A per channel
[NEW] FoC Mixing Techniques allowins mixed color FoC as well as traditional and popular "On-top" type Flash on Clash
[NEW] Pulse Fx
[NEW] 2 on-board LED driver (backward compatible with NB3) + 1 remote PEx for a 3rd channel (PEX not included)
[NEW] RGB Neopixel / WS2812 (and alike) support with power saving and adjustable timings
[NEW] Omnisabers support / Omnisabers Ready
[NEW] Override master file + individual configuration files for font specific settings
- 3 fonts - Long press on the activation switch when blade is off make the saber switch to the other font. Comes with Lightmeat and Darkmeat and Greymeat.
- Flash On Clash™ (FoC™) compliant using built in Power Extender
- Improved file fetching, up to 16 GB µSD card, drag and drop compliant (tested on PC at least)
- Dimensions : 1.12" x .73" x .20"
- Power supply : 3.4 to 5.5v / 2A (with the High-power LED). SINGLE li-ion cells (18650 or 14500) or 4xAA rechargeable NiMH batteries recommended.
- Idle current consumption : < 0.09 mA (deep sleep mode)
- 7+ months of shelf time with a fully charged 18650 li-ion cell
- 4A high-power LED direct drive (no current regulator)
- Speaker : 4 to 8 ohm.
- Audio output Power : 2W max
- Exported 3.3V pad
- Handles only momentary switches for blade activation
- Blade Flickering Fx
- Blade Shimmering on Clash
- Anti Power Off technology (A-POP™)
- WAV file support
- Changeable sound fonts, drop in support of CF/PC fonts, extra sound files are ignored.
- 10 bit, 22.050 ksample/sec audio
Warranty
- Warranty is for 30 days from the date of purchase.
- Warranty covers defects in workmanship and materials under normal use and service.
- Damage due to improper soldering will void the warranty.
- Warranty does not cover shipping charges to send it in for repair.
