2.5" long with 2" unthreaded.
Designed to hold 1" blades.
1.45" OD
2" long (not including male threaded section)
Holds a 1" blade
Holds a 1" blade
Average rating 8 out of 10
Good little emitter
The inside is a little tight, so I couldn't fit certain blades without modifying the inside via sanding. I don't suggest putting the blade retention screw in the center because that is the thinnest part of the emitter, it is easy to over tighten and potentially strip.
