Canadian Customers
MHSV1 Clamps & Boxes
Canadian Customers
Canadian 7.4v Li-ion 2600mAh 18650 Battery Pack
C7418650
$23.50
Also in Canadian Customers
THESE ARE FOR CANADIAN CUSTOMERS ONLY
Made with 2x 18650 cells and is PCB protected.
5.25" long and roughly .75" in diameter.
These are wired with a JST connector that is compatible with the Modular Wiring System.
DO NOT USE LiIon batteries if you don't know the dangers about them and how to handle them. Please check out this resourceful
website
on handling, charging, storage of LiIon batteries. Use at your own risk
Canadian Panasonic Li-Ion 18650 3.7V 3400mAh PCB Protected Rechargeable Battery
$17.99
Canadian 7.4v Li-ion 1050mAh 14650 Battery Pack
$16.99
Canadian 7.4v Li-ion 800mAh 14500 Battery Pack
$15.95
Slothfurnace ROTJ card for box 28 upgrade
$12.00
MTN Neck Style 9 Copper
$25.99
MTN Neck Style 8 Brass
$19.99
MTN Neck Style 8
$7.49
12mm KR Aluminum Duo Tactile Switch w/6" Leads
$14.50
