MHSV1 Clamps & Boxes
Hilt side Adapters
PCB's and Pins
1" Thick walled Trans White parabolic Pixel blade tip
1TWTHICKNP
$5.50
Also in 1" Thick Walled Blades
Transluscent white parabolic tip with shoulder for 1" thick walled blades. Has a hollowed tip for the neopixel to recess into.
These are created using new material that will illuminate way better than the previous white tips.
40" LED blade diffuser for 1" thick walled blades
$3.95
1" Thick Walled Pixel Blade Adapter
$4.00
Foam tube for 7/8" thin and 1" thick tubes V2
$7.00
Slothfurnace ROTJ card for box 28 upgrade
$12.00
MTN Neck Style 9 Copper
$25.99
MTN Neck Style 8 Brass
$19.99
MTN Neck Style 8
$7.49
12mm KR Aluminum Duo Tactile Switch w/6" Leads
$14.50
