Tri Cree Pre-Wired LED & MHS Heatsink Module. Plug and play for the "TCSS Edition" NBV4 Assembly. This version is wired specifically to be plug and play with the harness on the NBv4 assembly and not the standard pre wired NBv4.
Includes the following parts
- Flat copper heatsink module
- Tri Cree LED
- Tri LED Lens
- Thermal Tape
- Header and Harness
- .3 Ohm 1w Resistor
- 1 Ohm 2w Resistor
