• Royal Blue/Green/Red Cree Star LED & 1" Heatsink Module for use with NBv4 Assembly
Item #: M-1TCRBGRHM
Our Price: $43.50
Tri Cree Pre-Wired LED & 1" Heatsink Module.  Plug and play for the "TCSS Edition" NBV4 Assembly.  This version is wired specifically to be plug and play with the harness on the NBv4 assembly and not the standard pre wired NBv4.
These modules are not MHS and are not designed to work with either system. They are designed to work in builds that have a 1" ID.
Module dimensions- .994" OD x .8" Long (Not counting Harness)
Includes the following parts
  • 1" Heatsink Module
  • Tri Cree LED
  • Tri LED Lens
  • Thermal Tape
  • Header and Harness
  • .3 Ohm 1w Resistor
  • 1 Ohm 2w Resistor
