Mill cut Square Knurling
- This is for one section and cannot be broken up. For example if you want two 1.5" sections on a piece then you must order the 1.5" service twice and not a single 3" section.
- Pricing starts at $22.50 for a 1 inch section.
- Please be very descriptive on location to be knurled and on what MHS piece.
- Must be done on a flat area and can be done over the threaded section of a part. If done over threads (.75" or less from end), the knurling is shallow and not as defined (as pictured)
- This service is not available for the 4" extensions with a larger OD.
- If done over powder coating we cannot guarantee the edges will not chip along the cuts.
( based on 2
Great Design and Texture
Back when Fallen Order was being teased with pictures of sabers, the square knurling had caught my eye at that time and I opted to create a long-handled saber for flow-work. At the time, TCSS did not have square knurling service but I requested if such an option could be accommodated with the largest "raised squares" available. They pulled through. I've painted the surface over with a rose gold stain spray paint. It's since worn down, revealing the aluminum squares while the grid-like grooves still have the rose gold paint, looking weathered. It's been my favorite knurling design since. TCSS did a fantastic job with the knurling, looking clean and seamless.
Beautiful.
Beautiful knurling, great finish, and surprisingly good for grip.
