Cart (8)
MHSV1 Clamps & Boxes
Shipping & Returns
Pixel PCB - blade side
NPBSPCB
$4.28
Also in Pixel Blades
NeoPixel blade side PCB V2
The blade side adapter has a spot for a resistor on the data line. If you do not mount a resistor using those pads then you need to bridge the pads for the PCB to work.
MHSv1 Pixel Hilt Side Adapter
$6.20
More Info
Pre-Soldered Pixel PCB connector and 11 pin set
$20.95
More Info
Pixel Hilt Side LED Module Adapter
$4.00
MHSV1 Blade Holder Style 1
Qty:
Update
Delete
$15.75
MHSV1 Blade Holder Style 19
Qty:
Update
Delete
$15.75
.81" Double Female
Qty:
Update
Delete
$8.00
MPS Pommel style 1
Qty:
Update
Delete
$8.00
Double Male Extension
Qty:
Update
Delete
$15.75
MHS Extension Blank Style 3
Qty:
Update
Delete
$17.25
4" Double Female Grooved without holes
Qty:
Update
Delete
$31.50
Subtotal:
$120.00
