7" Knurled double female connector. These do not share the same Knurling pattern as our Custom Service. These are a much finer knurl similar to a Maglite.
You can select to have no switch hole or a Standard, Guarded, AV, or Recessed AV switch hole which will be machined 1.5" from one end. If you would like the hole in a different location then please order it without a switch hole and order the switch hole service instead so you can specify the location.
