MHSV1 Clamps & Boxes
MTN Blade Holder Style 1
MTNBH1K
$32.50
Also in Thin Neck System
Designed to be used with a 1" Pixel Hilt Side Adapter which is held in place by
2x 4-40 set screws
(Included)
. The blade holder has
3x 8-32 set screws
(Included)
hidden under the outer shroud.
The outer shroud is
left hand threaded
so that it will not unthread the rest of the parts when being loosened. When tightening it hold onto the blade to help snug it down without unscrewing the rest of the saber parts.
Blade depth with our Short 1" pixel adapter = .62"
1" Short Pixel Hilt Side Adapter
Blade depth with our NPXL 1" pixel adapter = .538"
1" NPXL V3 Hilt Side Adapter
Will screw onto any female MTN part.
All MHS parts should have the threads wiped clean and then lightly oiled or greased. We sell some
Synthetic Grease
for this. Parts that get stuck because no oil/grease was used or that are damaged by the user trying to take them apart will not be warrantied.
MTN Blade Holder Style 2
$32.50
More Info
MTN short ribbed extension
$19.99
More Info
Brass MTN Ribbed Adapter Style 2
$27.99
12mm Nut
$0.50
MTN short blank extension
$19.49
MTN short ribbed extension v-grooved
$23.99
$19.99
1" Blade Dust Cap - Red
$1.55
