• MHSV1 Blade Holder Style 18
Item #: holder18
Our Price: $28.25
Include Heat Sink?
Adds 2" to length of saber and has 1.7" max OD.
Designed to hold 1" blades.
Average Rating:
(based on 7 reviews)
Showing 1 - 5 of 7 Reviews:
RatingReviewerReview
by Dan
on 7/4/2020
from Winchester
Perfect
Amazing emitter! The quality is top notch. Just remember it has a thick wall take that into consideration when getting a blade retention screw. If you are new to the hobby I would suggest getting TCSS to do it for you. I had no problem doing it on my small drill press. As always May the force be with you
by Tyler
on 12/11/2019
from Cashmere
Really great blade holder
Really looks great on any saber and I love it on my saber. Can’t say anything else good on it. Just really awesome.
by JOHN
on 6/5/2019
from APO
Great Product
This was my second choice for an emitter and i wish that i had started off with this. nice and solid, great threads, really gives the saber the finished look that . you're looking for.
by Tyler
on 11/19/2013
from Spokane
Elegant and able
This emitter is clearly from a more civilized age. The heavier flare at the base of the blade holder makes for a brilliant place to grip the saber, and the weight makes it great for spinning and dueling. I highly recommend it.
by Ronald
on 11/8/2010
from Deerfield
Great Blade Holder
This item is much more beautiful in person and is a great addition to any saber project. The holder is designed for a 1" blade. Make sure to get it drilled and tapped because it does not come pre-drilled for a blade tension screw and also does not come with a blade tension screw so make sure you get one. Overall, great product.
12
