Complete Pixel LED Trans White Show blade.
The blade is assembled with the V2 Pixel Stick, Foam, "TCSS" Style plastic diffuser for extra diffusion, and a Parabolic tip. There is no custom lengths and the Blade is offered at a fixed 35.375" in length.
NOTE: You will want to set your strip configuration to 132 LED's.
The blades are not designed for Dueling. These Blades include a 90 Day warranty and it does not cover any damage to the blades as a result of Dueling or Bashing. If a blade is returned back to us showing signs of abuse, the warranty is void.
