MHSV1 Clamps & Boxes
Bullet Shaped Clear shouldered 7/8" thick walled blade tip with reflective disc
C78Bullet-R-THICK
$3.50
Also in 7/8" OD Thick Walled
Clear shouldered 7/8" bullet blade tips with reflective disc for 7/8" thick walled tubes.
Clear Parabolic 7/8" thick walled blade tip with reflective disc
$3.50
7/8" Thick walled Clear PolyC 40" long
$9.75
More Info
$3.50
Slothfurnace ROTJ card for box 28 upgrade
$12.00
MTN Neck Style 9 Copper
$25.99
MTN Neck Style 8 Brass
$19.99
MTN Neck Style 8
$7.49
12mm KR Aluminum Duo Tactile Switch w/6" Leads
$14.50
