Pixel blade side PCB V2 with the SMD resistor Installed.
SO glad TCSS makes these available!
An absolute must if you want to build your own pixel blades. Can you imagine trying to solder the tiny surface mount resistor yourself!!!!???? No way. TCSS does the job for you. Home run!
