MHS OWK
Price: $263.21
  • SKUMHSOWK
MHS OWK Empty Hilt Kit
  • 1" Blade Emitter includes blade retention holes and screws
  • Working replica graflex clamp with "Graflex" stamped on the back. Manufactured using the same methods and materials as the original screen used clamp. Does not include a bubble strip.
  • Two Faux transistors included to be installed in to the clamp
  • Includes a vented and non-vented pommel insert. Compatible with any MHSv1 MPS Insert. If you want us to install either of the included pommel inserts prior to shipping, please let us know via an Order note!
  • D-Ring is pre-installed in to the pommel for your convenience
  • Utilizes all MHSv1 and MTN parts allowing easy customizations or part swaps if desired.
  • A mix of 6061 Aluminum, Real Brass, and Steel with Machined and Anodized finishes.
Designed to be used with a 1" Pixel Hilt Side Adapter which is held in place by 2x 4-40 set screws (Included). The blade holder has 3x 8-32 set screws (Included) hidden under the outer shroud.
The outer shroud is left hand threaded so that it will not unthread the rest of the parts when being loosened. When tightening it hold onto the blade to help snug it down without unscrewing the rest of the saber parts.
Blade depth with our Short 1" pixel adapter = .62"  1" Short Pixel Hilt Side Adapter
Blade depth with our NPXL 1" pixel adapter = .538"  1" NPXL V3 Hilt Side Adapter
These are NOT a complete working saber and do not arrive assembled. The kit does not include a blade, LED, sound module, speaker, etc
All MHS parts should have the threads wiped clean and then lightly oiled or greased. We sell some Synthetic Grease for this. Parts that get stuck because no oil/grease was used or that are damaged by the user trying to take them apart will not be warrantied.
Brass parts may arrive with a patina but they can be polished.
Average rating 10 out of 10 ( based on 2 reviews )
Hello there...
Review by Sean on 4/23/2023
Bought the parts for this individually before the kit came out. It has a great heft to it, and really like the innovative way the retention screws were hidden under the reverse threaded blade holder cap. With a little bit of weathering and a custom installation of a Proffie core and it is one of my favorite hilts.
The best saber kit
Review by Adam on 3/31/2023
I just received this kit yesterday and I love it. The quality of each part is perfect. When assembled it feels great in my hands can't wait to buy the electronics and have it installed.
