White shouldered 1" thin walled blade tip with reflective disc
Item #: W1Thin-R
Our Price: $3.50
White shouldered 1" blade tips with reflective disc for 1" thin walled tubes.
These tips will light up if you cut a small section out of the middle of the reflective material or remove the reflective disk.
