TrustFire Protected 3.7V 900mAh 14500 Lithium Battery (2-Pack)
Item #: Trust14500
Our Price: $5.64
These will have the blue or the red flame graphic on them.
TrustFire Protected 3.7V 900mAh 14500 Lithium-Ion Battery (2-Pack)
MUST BE RECHARGED WITH A LI-ION CHARGER. DO NOT USE A NIMH CHARGER.
We recommend that the batteries be charged individually out of the hilt and not be setup as a rechargeable pack.
As with any battery they should not be left in the hilt for extended times while not in use.
- Shell material: steel
- Rated voltage: 3.7V
- Internal resistance: <= 100 milli ohm
- Low voltage cut off: 2.75V
- Over charge voltage cut off: 4.2V
- Maximum charge current: 1.5C
- Maximum discharge current: 1.5C
- Diameter: 14.0 +/- 0.5mm
- Height: 51.5 +/- 0.5mm
- Environmental temperature (operating): 0~45'C
- Environmental temperature (charging): -20~60'C
Activation box style 13
Price: $23.25
Activation box style 14
Price: $23.25
Activation box style 12
Price: $24.00
