Complete LED Trans White Show blade.
These blades are built using a 1"OD thin walled Trans White Polycarbonate tube.
There is no inner diffuser material in these. They work nice as is or you can add a few wraps of cellophane (available at most craft stores), etc to make it even nicer.
Reflective disc on the base of the shouldered tip is standard.
This is just a blade, there are no electronics included.
