Hasbro FX Kylo Ren conversion kit
Price: $22.00
  • SKUKyloKit
Hasbro Kylo Ren conversion kit.
Kit includes blade holder and heatsink for main blade only.
You will need to drill and tap a hole through the hilt and blade holder for blade retention as well as purchase a set or thumb screw.
LED, lens, and lens holder will need to be ordered seperately.
Average rating 10 out of 10 ( based on 2 reviews )
Perfect fit for 1" blades
Review by Alexander on 10/4/2016
Snug fit on the blade and great spacing. Lots of room for your choice of led and wire connectors if youre nervous like me. One quick bit about the saber itself. Closely examine picture #3 and you will see there was/is a ring on the main emitter held on by glue. Just in case anyone didn't notice already, very nice to know in case you were planning on drilling a retention screw through said spot. Also, this ring is not wide enough to accept a 1" blade so be sure to sand regardless of wether you remove it or not.
Great kit!!! Worked perfectly!!!
Review by Emperor vader on 4/4/2016
I bought three of these kits to convert three of my Kylo Ren fx lightsabers and I used this kit with no problems at all.
