• Clear bullet 1" thin walled blade tip
Item #: 1thinbullet
Our Price: $5.50
Bullet shaped tip with shoulder for 1" thin walled blades.
These now have a smaller mirror so the tips light up better
Average Rating:
(based on 2 reviews)
Showing 2 Reviews:
RatingReviewerReview
by David
on 7/21/2018
from Australia
Better than round!
I recommend these over even the clear rounded bullet. There is a slight gap around the mirror, allowing light to pass through to the tip. The mirror is great but as certain angles can shine a minor beam of the LED light back into the users eye. However, with a trans white blade this is almost irrelevant.
by [s]
on 9/13/2009
from Gig Harbor
ALMOST perfect.
this blade tip in my opinion looks wayyyyy cooler than the usual rounded off ones. i put it on my ultra edge and the shape just looks awesome. the ONLY problem is that when you put the reflective disc on, it causes the middle section of the bullet tip to be dim while the very end is bright, so you MAY want to skip the reflective disc and just use the tip without it and see if the blade will light evenly enough for you. over all i'm very happy with this product and i will most definately be buying many more
