Adjustable LED driver
Item #: ALEDD
Our Price: $35.00
LED driver with 6 constant current settings.
Turns on and off by switched input voltage.
Minimum input voltage = 6v or LED voltage +1v whichever is higher
Maximum input voltage = 20v
Heatsink should not be required unless you are running >10V of LEDs at 1.5A
Reverse polarity protected.
The driver size is 1.2" OD
The DIP switch settings are as follows:
SW1 SW2 SW3 SW4 SW5 SW6
ON OFF OFF OFF OFF ON 700mA
OFF ON OFF OFF OFF ON 800mA
OFF OFF ON OFF OFF ON 1000mA
OFF OFF OFF ON OFF ON 1200mA
OFF OFF OFF OFF ON ON 1400mA
OFF OFF OFF OFF OFF OFF 1500mA
