7.2V 800mAh Lithium-Ion Rechargeable battery pack with PCB protection.
These will plug directly into our Lithium-Ion smart charger's.
Red = positive
Black = negative
You can get the matching plug Here
These are the same size as 2x AA batterys.
Cautions
Use special caution when working with Li-ion cells, they are very sensitive to charging characteristics and may explode if mis-handled.
Make sure user has enough knowledge on Li-Ion rechargeable batteries in charging, discharging and assembly before use.
We are not responsible for any damage caused by misuse or mishandling of these Li-Ion batteries.
Strongly suggest that you use our smart Li-Ion battery charger to recharge the battery pack.
Never use conventional DC adapter to charge the battery module) We are NOT responsible for any damage that is caused by the misuse of the Li-Ion Battery.
